Well crap - I did a quick mockup on the new engine to check valvetrain geometry. Installed one head and intake/exhaust lifters in #1. Spun engine over a few times with magic marker on the valve tips. Looks to me like I need a shorter pushrod. I am running stock length pushrods in it right now. Block had maybe .006 taken off to square things up - pistons ended up .008 in the hole. Heads were milled around .025 to help bring up compression. Head gasket compressed thickness should be .039 - this is actually an old gasket that I put on temporarily for the mockup. I was hoping things would even out because cam was reground for more lift and had about .050 taken off the base circle. I actually thought I might end up needing slightly LONGER pushrods, not shorter.
Someone who has been down this road a few times take a look at these pictures and let me know if I am OK, or if I need to dump another $300 on custom pushrods.
