I'm Going to pull the heads apart here in the next few days to see just how lucky I gotNot a builder, but I don't see how the guides in that bank can't be AFU as well. Valves were likely pushed hard into one side of the guide, I'd expect cracking or at the very least uneven wear.
Honestly, it looks like you've averted a total disaster - one valve head snapped off and it hits the fan very, very quickly.
I'm not sure, but my timing was locked out at 34 degrees. I looked at all the push rods they were in good shape with no deformation or bends. Only the cam lobes for those cylinders showed abnormal wearI'd check all the push rods, doesn't Adv. a cam bring the exh. valves closer to the piston and Ret. the cam bring the int valves closer or is that the other way around?
Advancing the cam and advancing the ignition timing are two different things. Advancing the cam affects piston-to-valve clearance, advancing the timing does not.I'm not sure, but my timing was locked out at 34 degrees. I looked at all the push rods they were in good shape with no deformation or bends. Only the cam lobes for those cylinders showed abnormal wear
If your cam looks "Abnormal" I'd pull the cam and either flush the engine real good or pull it out like others have said but that's where it's open up the wallet time and your engine is down awhile, parts supply chain issues?
Bill is right on. Everyone (or us non-pros) check P/V with clay measured on the flat of the valve relief but no one (except a pro) checks radial clearance. I ran into the same issue with set of GMPP ZZ502 heads (these have 2.25 intakes) , and it was worse, 7 bent valves and 1 lost valve it got beat so bad. Your pistons are Speed Pro Hypereutectic, they are only made for stock valve sizes. My block had to go from .030 to .070 to clean up the one cylinder.The culprit is the fact that you dont have enough clearanceProbably was close before you decked the engine and now you pushed it over the edge. How much cylinder wall clearance do you have ? The pistons are probably walking around a little bit too.
When you did that how much clearance did you have atr the edges ? I like to see at least .050"
If the valves touched (which they obviously did) I would definitely have them pulled out and lightly refaced to be sure. You would be amazed at how a valve spring can pull a slightly bent valve closed.
Has the one head been milled more than the other ? Or the valve seats not cut in to the same depth ?
The pistons should be fine but I would pull all 8 and have them fly cut to give you enough room, especially if you are going with a larger cam. You need to be VERY careful having this done because it is very easy to cut into the top ring groove on those pistons.
Its all simple engine building 101Check everything and then check it again.
Everybody's fingers are crossed for you, brother!I'm Going to pull the heads apart here in the next few days to see just how lucky I got
Those pistons are usable just fly cut the valve reliefs, either get a Good hyd flat tappet or a Good roller cam and Good lifters, if you go roller cam you'll want to watch Scott Foxwells Youtube vid about setting up valve train geometry, that's if you're using roller tip rockers.
that is ugly;motor is already out and on the stand. So I have no problem tearing it down. Cam was getting swapped along with new pushrods lifters and rockers. Might be more in the short block now. Here's a few shots of the affected lobes
For the OP and others, just to be clear, yes most of us amateurs, (myself included) use the clay method, but radial clearance can still be checked with the clay method, (that's what I do). Radial meaning the distance between the valve circumference and the beginning inside edge of the valve relief, ( the "eyebrow"). Some sources claim that the absolute bare minimum is .030" of radial clearance, but .050" is better. And I'm pretty sure that some pistons will rock in the bore during engine operation more than others. So that's just one variable that needs to be accounted for when considering radial piston to valve clearanceBill is right on. Everyone (or us non-pros) check P/V with clay measured on the flat of the valve relief but no one (except a pro) checks radial clearance. I ran into the same issue with set of GMPP ZZ502 heads (these have 2.25 intakes) , and it was worse, 7 bent valves and 1 lost valve it got beat so bad. Your pistons are Speed Pro Hypereutectic, they are only made for stock valve sizes. My block had to go from .030 to .070 to clean up the one cylinder.
