I pulled the motor to swap from a worn flat tappet to a new hyd roller and while it is out, I'm doing a little poking around.
Cylinders 2,4,6,8 have come in contact with the valves. 4/8 are the worst and 2/4 are slightly affected.
None of the pistons on the right bank have come in contact.
last time the motor was apart, I had the block 0 decked. I did clay the right bank but did not do the left in a rush to get it back together🤦♂️
I did not have an issue before the motor was decked.
The heads and valves seem to be ok to my untrained eye.
I filled up the chambers with alcohol and did not get anything passed the valves with the springs in. No makings on the valves that I see.
-20cc speed pro hyper domed pistons
781 heads with 2.19 and 1.88 valves
Comp cams 286H
1.7 roller tip rockers
Has anyone had any experience with somthing like this, and if so what was the culprit? Why would this only happen on one bank and do I need to replace the pistons?
Comp cams 286H
