Good day,
I like to know if my valves are correctly adjusted or that I need to tuned-up.
What is the correct valve clearance for the intake and outlet valves by a cold engine?
Me and my mechanic are from Holland and having a hard time to find the correct sources.
I'm running a 350 block and as far as I know, except for my cammel humb heads, is everthing standard. Or at least I didn't discover any special (preformance)rockers.
Many thanks in advance!
Michael
~who is very happy that finally his 'velle is in his own barn after 8 years~
· In Memoriam
need to know what cam you have to say anything meaningful about the adjustment. Is it a hydraulic flat tappet? A solid roller? have a grind or part number?
Is it noisy? Is that what is driving this work?
@Tom
I don't know what cam I have. This sunday my car will be transported to a garage, then I will take a close look and search for the part number. As far as I have found out I'm running solid rollers.
Yep it's noisy. It's making a tikking-sound.
@Mike
Thanks for the link
Michael
