having issues with my guide plate and valve train alignment I think on a couple of intake valves. The picture is #1 intake. My guide plate is adjusted as far as it will go without causing the pushrod to rub the intake casting on my edel rpm heads but doesn’t seem to be far enough to get a good pattern? Can I run it as is or am I looking at a valve guide problem down the road? I checked and removed the rocker 3 different times with pictures each time below. The patterns are shown with full valvetrain load, no checker springs. The width of the pattern seems wider than it really is with my hyd lifters bleeding down with spring pressure, but that wouldn’t affect the left side wear.
will I have to grind the casting?
