I often see listed on performance heads for use with a hyd roller or solid roller cam only. Does anyone know what if any difference is in springs between a hyd and a solid roller cam given the cam specs were virtually the same?
I am asking because I have a set of GM performance heads that I am finding little info on. They are fully assembled new oval port heads I am unsure of the valve springs that are on these heads if they check out pressure wise I still don't know if I should use them.
Thx
Thx
