A double pumper is one thing and a carb with vacuum secondaries is another. Double pumper refers to a carb which has accelerator pumps and power valves for both the secondaries and the primaries. Carbs with vacuum secondaries aren't typically double pumpers. More typically, mechanical secondaries and double pumper set ups go together.
Not to say you COULDN'T have a double pumper with vacuum secondaries, it just wouldn't be all that effective or work that well. Double pumper Holleys usually have dual fuel inlets as well.
