Since I recently converted my 69 to a 4 speed I've got the harness for the neutral start switch just hanging around. Now, I've got a jumper wire in there so that it thinks the switch is in neutral all the time. I'm wondering if I could put a small switch in there to disable starting the car. Could someone hotwire the car if that switch is off (thinks its not in neutral) ???
1969 Caprice (It's not an Impala darnit!)
427/M-20 Finally!
12-bolt 4.10 Posi
13.45 @ 105
1966 Caprice
396/325 TH-400
15.38 @ 97.4
Andy and Nick's Muscle Car Half-way House
I am putting a kill switch in my car that works on this idea.
It splices into the wire form the neutral safety switch, so that when the kill switch switch is off, it is like the neutral safety switch isnt activates, so it wont start.
And i'm pretty sure it cant be hotwired with this either.
-Matt
1971 Malibu 350/TH350 (soon to be 383/4 speed)
"DRIVE IT LIKE YOU STOLE IT!"
CAR
ENGINE
Gold Founding Member
Might slow someone down a little but everybody knows how to crawl under and jump the solenoid's bat cable post to the purple wire post
(or even do it from under the hood for that matter)
Maybe that and a few other tricks too such as a hidden swhtch that completes a ground circuit to the coil's neg. terminal or a switch that sends a ground circuit to a relay that breaks the main power circuit coming from the horn relay or maybe one the kills the power to an electric fuel pump
Always park "backed in" so a tow truck can't lift the rear tires off the ground or keep the steering wheel locked in a turned position maybe
And check out Wes Van's hood lock in the reference section
Dean Call
Team Gold member #3
A.C.E.S. # 00235
Mid America Chevelle Club #001
chevelles.net
My 69
ACES/Midwest Chevelle Regionals
Don't point a finger - lend a hand
I prefer sleeping in the car with a brick.
Tom Parsons
If they want your car, they will find a way. Fuel shut-off is the best. GPS tracker will get the car back.
I think best anti theft device is set of full wheel cover hub caps! Nobody would give the car a second glance...until you started it
1969 Nova SS 350
406/M20/3.55
13.68 at 105
