am i right in thinking that the Custom Autosound USA-2 stereo will be a plug & play affair on my 1969 Chevelle? the stock set-up was an AM radio and an 8-track. it appears to have stereo rear speakers... as well as a single under dash speaker and 2 kick panel speakers.
i am also assuming that the kick panel speakers that Custom Autosounds sell are also a plug & play deal?
also... does the USA-2 have a 'normal' aux input on the back? like to plug an ipod into? or is it a proprietary input?
thanks!
You will end up soldering their harness into your existing harness if that's the question.
ah okay... so the current harness will not just plug right into the USA-2? does anyone make pre-fab harnesses? i'd rather not cut/mutilate the stock harness if i don't have to.
You can run their harness back to the fuseblock and directly to the speakers. Saves your original harness...but you still need to use thier harness.
