How can I replace the fitting. It's a 1/4 28 taper straight zerk. Heli-Coil which one? UNF Free Running or UNF Screw Lock? I ain't no machinist, which type?.
Or is there a better way?
A little more info??? Is it the ball joint fitting? Did the threads strip or did it just fall out? worst case is that if you cannot solve the fitting problem and it is your ball joint just replace the ball joint. Not much money involved there.
The zerk fell out. Threads are stripped. Where can I get a size bigger and what is that size?
Thanks.
