So on my '71, the rear bushing on the front upper control arm has cracked and pretty much popped out of position. When I turn the wheel I hear a clunk
as the control arm must move from one position to the other now that there is clearance there. I have never worked on the suspension before so I have a couple of questions for the pros out there.......
1. Can I drive the car like that or am I just making matters worse.... I think I know the answer to that one....
2. I notice when I jack up the car from under the lower control arm it frees up the upper control arm so that I can move it by hand since the rear bushing is gone. My question is can I remove the bolt the holds the rear bushing in, slide off the old bushing and sleeve and press a new one in WITH the upper control arm still in the car ? It moves around pretty easy when jacked up.
Or am I just dreaming ? :wacko: Thanks....
