Hey guys,
Background: Currently stationed in Germany. Bought the motor from someone who claimed rebuilt as 468 but I doubt it. Redid cam, oval port ProComp Aluminum Heads with Comp Cams hardware and Oval Port Air Gap with 850DP. Running a T56 (Yeah its awesome) behind it for the long commute and Autobahn. After she was done in the states I had it shipped over here.
Got an issue. Just got the Chevelle over here and couldnt be happier. I havent revved the engine past 3,000 RPM and the break in oil was just changed. However, it recently started smoking out of the driver side. I didnt notice a real difference in power however its a bit irrelevant as my old engine was a 350 and much more mild and this engine is new and Im still tuning the carburetor. She smokes more when its warmed up and I noticed less in the morning than in the afternoon, its also not consistent.
Bad news: Did a compression test and all on driver side came back as 125 psi but number 7 was at only 25 psi. All plugs were black (playing with carb still I guess), but number 7 looked unburnt and had fresh oil on it. Only thing to add is that that plug has always felt like its slightly misthreaded. It was harder to take off when I first got the car and put on (the others I can hand tighten all the way. I figured this is irrelevant however due to the fact that it still had oil on it and looked unburnt. They didnt have the equipment for a leakdown.
Well guys... What do you think. I still need to do the leakdown, but what are my options. I dont have a billion $ to blow but if I have the engine out and apart I may as well stroke it and put new higher compression pistons. Or I could just say to hell with it and sell it to a German and buy an LS (already have a T56). I really love that big block, but I know now it was down on power (lugs a bit uphill etc) because its on 7 cylinders.
Just looking for any advice really. Some guys I talked to here that have done this a bunch of times in the past seem to think its an easy job that would take a day to do.... Just not sure really. Its a real dissapointment because I just got the car done and here and a ring goes out. I will be leaving this summer sometime for an extended vacation in Middle East, so I may just wait and get it done while Im gone....Any advice/opinions/tips from you guys is greatly appreciated
-Paul
BTW Holy %[email protected]# does this thing sound mean. Lovin it as a daily driver
-Paul
