1 - 20 of 37 Posts
· Vendor
UMI Performance, Inc.
Drag Anti-Roll Bar for the 1964-1972 GM A-Body
P/N 4045
UMI Performance, Inc. is pleased to announce the availability of our new Drag Anti-Roll rear sway bar for 1964-1972 GM A-body applications. This 1-3/8” dia hollow sway bar is axle tube mounted using our tried and true CNC machined serrated tooth mounting clamps, aluminum bushing mounts and heavy duty u-bolts. Strong double shear mounts and four high grade 3/8” fasteners attach the race quality rod ends to the chassis. Three position adjustability delivers enough roll resistance to tame your 11 second drag radial car or your 8 second full slick strip missile. The UMI manufactured hex adjusters ensure a perfect fit and provide preload capability to straighten your launch. The P/N 4045 drag bar has been designed to accommodate the factory rear housing, 12-bolt, Ford 9” and Moser M9 while still offering great ground clearance and a clean look (available for 2.75”, 3.00” and 3.25” rear axle tubes). These bars are available with tough red or black powder coat and are designed and manufactured with pride in Philipsburg, PA.
www.umiperformance.com or 814.343.6315
Can you post some pictures of what they look like installed? Especially how the end links look when attached to the bar and the frame.
I see you have an introductory price on your website. How long will that price be good?
· Vendor
Hello, I posted a few in the drag bar thread yesterday... did you happen to see them?
Thanks!
Had to do a search for the post. That post doesn't show up on the threads any more when I go to the Brakes, Suspension & Steering page. Looks like the ends links are much more vertical than on a Spohn bar. The bars are the same for 64-67 and 68-72? The 68-72 has a shorter wheel base so the bar would reach further under the channel, right?
· Vendor
Yes ours will sit straight up and down. We actually put quite a bit of time into this design so it fit properly with all the years. We also strive to offer some of the best products on the market.
There are three holes which is what allows it to work well with all years, two holes work best for 68-72 and two holes work best on 64-67. The third is usable as well but the link won't sit as straight up and down. Basically all three holes work on all years but two will work best on 64-67 and two on 68-72.
Here is the link, post #31- http://www.chevelles.com/forums/showthread.php?t=445641&page=3&highlight=umi
Thanks for looking,
Ryan
· Vendor
· In Memoriam
Ryan, I've seen various pics of "other" bars installed with the links at a pretty nasty looking angle. I know you're an engineer and not a salesman, in your opinion is this because of a "one size fits all" mentality at the manufacturers? It seems like a guy would want the link pretty much vertical at rest so as to avoid nasty angles at extension and compression.
Seems like moving the link to the front or back holes in the bar would change the effective arm length too? Any wisdom on running the link in different holes on the left and right?
· Vendor
Ryan, I've seen various pics of "other" bars installed with the links at a pretty nasty looking angle. Is this because of a "one size fits all" mentality at the manufacturers? It seems like a guy would want the link pretty much vertical at rest so as to avoid nasty angles at extension and compression.
Tom, my assumption is yes on this. Some angle is okay until the point the bar rotates during launch.
· In Memoriam
Sorry, Ramey, I edited my post with more questions while you were answering.
Ryan,
UMI Performance lists this bar as a drag bar. I see there are three different rates available, I would assume by using one of three different mounting holes - the furthest probably for street/strip - the closest for drag/slicks? What is your thought on the application of using this bar/kit on a street only car? Thanks
Sam
Ryan,
Sam
Hey Sam.
The bar is intended for strip use but of course is safe for a street car. The key is that street car is street/strip and not street/handling. A drag bar creates such a huge roll resistance out back that the rear will step out on hard cornering. With that being said, we have a lot of F-bodies on a similar bar, including our house car, and it works fine for general driving. It's just not for handling. You could use one for drifting I guess...
And yes, on the rates. Longest hole is softest, shortest hole is heaviest. The bar is so heavy on purpose that changing that rate would make a minimal difference though, and would be for fine tuning. We intend the front two holes to be for 64-67 and the rear two for 68-72. All three settings will provide enough anti-roll to help the A-body launch straight and true.
See the thread at the below link for that exact issue. Look for my posts on pages 2 and 3 with the photos and the sketches of what happens.
Hey Tom.
During our design we never considered anything but vertical links at ride height - it was one of our design criteria to not have a weird link angle. Our bar should achieve vertical on both chassis (64-67, 68-72) due to the hole spacing we selected. Our customers seem to hold us at a high standard, I guess :D, so we try to make sure fitment and function is as nice as possible before a product release.
As for offsetting the end links, I haven't really thought about that yet. We have had some good success with offset shock settings resisting body roll on drag cars so I'd imagine something could happen in the bar area. I'll have to put my theory cap on and think awhile...
One thing with the anti-roll bar, the rates are so high on purpose it might not matter much. As an example, some anti-roll bars are in the 2500 lb/in range and some are in the 1500 lb/in range on the same type of product from different manufacturers. Both bars functions have great reputations in the industry so it seems that once we get so high, any additional rate neither helps nor hurts. There's probably a point where it's just too much and would render a car too stiff but we don't approach that number in the industry that we know of.
Ordered mine on May 20 and still have NOT received it! It shipped on June 4 and was supposed to deliver June 6. UPS seriously screwed up my weekend. It's been stuck in Jacksonville (excuse was broken rail car?) since June 6 and now say it won't deliver until June 10! It only takes 3 hours to drive from Jacksonville to Tampa. Arrgh!! Put the damned thing on a truck and drive it here!!!
Are you not coming out with a "pro touring" set up for street use? I am interested, but am looking for a solid street set up. I like the idea of bolting on to the rear axle.:hurray:
ken
Hey Ken. Our 1" Pro Tour version is only days away!
Same hardware and configuration as the drag bar, just in a street friendly diameter.
-- Ramey
Sent from AutoGuide.com App
:thumbsup: ok. I might have to take something apart to take my mind off of it while I wait....:D
Darn you UMI Perf,
now I will be spending more $ on this great designed Drag Bar !
It is great to see the pics of how the UMI Drag Bar was properly designed and how it is installed
VS the other one (Sophn) that was not done right !
Great thinking/planning and designing Ryan/Ramey and the rest of the Gang Members .
Still have not got my last purchase from you guys installed on the car yet,
UMI Perf 64-72 GM A-Body Tubular Upper & Lower Front A-Arm Kit # 403133
UMI Perf 64-72 GM A-Body Viking Front Coil Over, Dbl Adj Shocks # A205-550T
UMI Perf 64-72 GM A-Body Viking Rear Dbl Adj Shocks # B220
either I am to busy or the shop that I get somethings installed at is to busy .
1 - 20 of 37 Posts
