I have a 77 350 block +.060 and 010 and 020 block with 4 bolt mains. Mildly ported vortec 062's with 1.94/1.5's. has better valve springs good to .525 lift. Keith Black 12cc d cup dish pistons. .024 down the hole with .016 gasket to get .040 quench. stock crank and rods. thinking about using the 60103 lunati voodoo cam. looks about right for my rpm range. gonna get 2400-2800 stall for 700r4 transmission with 3:73 posi gears. 28" tall mickey thompson sportsman S/R or S/t cant remember which the flame pattern ones. 28 X 12 tires. 12 bolt rear end.
Any suggestions welcome. just keep in mind that its hydro flat tappet and up to .525 lift and i am not changing that. thanks
Logan
Need more details like, what intake, what you are going to do with the engine, what rpm range are you looking for, whats it going in, etc?
Weiand Speed Warrior Vortec intake. Summer cruiser, maybe see the track once or twice. RPM range 2000 or so to about 6000. Going in a 1969 Chevy Custom/10 pickup weighing about 4000lbs. Going to use a Carb adapter to fit Quadrajet on the square bore flange. anymore questions just ask.
thank you
