Well it happened again, the turn signal started working and then they died out after a couple of days. I did notice that right before the signals died out there would be delayed and then they completely died out. When my turn signals died so did my heater and the light on the dash that says, "GEN" blinked twice. I switched the voltage regulator and it now the "GEN" light blinks and it makes the horn relay buzz. As for the turn signals they still don't work. I don't know if this is unusual, but when I hit the turn signal to the right and I hit the brake the Left brake light comes on but the Right doesn't. When I hit the Left turn signal the Left light doesn't come up and right brake light does. Do you think it is the horn relay causing all this trouble? Or Do I need to change the turn signal switch? Someone please help?
