Guys, the turn signals are not working on my son's 95 GMC Jimmy. The emergency flashers are working fine, however. Checked the fuse and it is good. Don't know what the problem is. I looked and can't find the flasher, if there is one. Any ideas? Thanks...
The flasher is located on the "convenience center" behind the center of the instrument panel. The signal flasher and the emergency flasher are separate flashers, both are in a single component. You should be able to turn on the emergency flashers then locate it by the sound it makes. I suspect the flasher is the problem.
