Greetings! You know how it is, you fix one thing and something else goes wrong. I have turn signals, at least they turn on with either left or right, front and back, but they don't flash. I've replaced the flasher twice, but both came from my garage. They look new enough, but that doesn't mean they work. Any other possibilities?
Thanks.
Administrator
There are 2 flashers, the one in the fuse box is for the hazards. The TS flasher is under the dash by the steering column mount. Which one did you change.
The one on the fusebox. I'm going to take the one for the 4-ways and put it in the turn signals and see if that works...
