1 - 8 of 8 Posts
Hi everyone. I'm hoping someone will be able to help me. I have a 69 Chevelle. My turn signals stopped working, so I changed both the hazard and turn signal flasher cans(just to be safe). Now only the driver side lights work for both the hazards and the turn signals. I get nothing from the passenger lights. Can anyone shed some light on this matter for me. Thanks in advance for the help.
That is a little strange. The hazard can uses the same wires as the brake. If the left rear is flashing so should the right. Try this and see if anything changes on the right rear.
Turn the hazard flasher on.
Gain access to the right rear bulb.
With the bulb still installed in the socket:
Touch one end of a jumper wire to the bulb base. Right where the bulb base meets the glass.
Touch the other end of the jumper to a known good ground.
See if that changes anything on the right rear bulb.
1 - 8 of 8 Posts
