Ok to some of you guys it might not be a problem but to me I must be stupid....because I can't figure out why my left signal blinks like a normal turn signal and the right blinks about once every 15 seconds...what gives guys...thanks again, email me if you [email protected]
3- Sometimes, not often, it can be the flasher can. One side pulls just a little more current than the other. The flasher can is the one under the dash.
I'm experiencing the same problem in my '71. I replaced the can with no luck. I'm going to try replacing the bulbs and checking the grounds.
i found the problem with your helps guys...it was the connectors..they had corrision in them that wasn't notice until I sat down and run each wire with a meter...thanks again
