Gauge cluster '70 dash, converted from idiot lights to gauges last winter. My problem is in the turn signals - when I use them, both sets of dash lights light up, alternatively, bright then dim, but both remain lit.
Signals appear to work fine from outside the car.
Any step-by-step process I can go through to fix this litte nuisance would be greatly appreciated.
Check the screws that hold the circuit board to the back of the dash housing.They also act as grounds for some cuircts. I had a similer problem that acted on&off for years. Turned out that one of the screws where not tightened all the way to make good contact. Jim.
I had a problem like that, the front bumper wasn't grounded because the filler panel was missing. I ran a wire to it and it works like new. You've definitely got a ground problem somewhere, something's getting it, but the connection's bad.
1970 Chevy Custom El Camino
Originally was & will be Green Mist & Silver w/Green Vinyl Top (now black/black)
350ci/300HP 4bbl & Dual Exhaust
TH-350 - 2.73 Posi Rear - Factory PS, PDB, PW, Tilt, A/C & More
My El Camino Home Page
Also, check out my new 1987 Chevy Caprice Coupe!
Other Restorations - 1969 Snowco Trailer & 1967 Sears Custom 600 Tractor
Team Chevelle Member #995
Thanks for the posts - I checked the operation of the signals outside the car this weekend - they work fine whether the headlights are on or off.
Because they worked, I did not check the connections at the housings or for the bumper. I will do that in the next day or two. I will also double-check the back of the dash and make certain those are tight, I know they act as ground connection for the pcb. My housing overall has more than one good ground.
