Throwing this out there as I'm chasing this electrical gremlin. The green turn signal indicator lights in dash stay on with key in ignition. Both turn signals work as they should. I pulled the flasher which feeds the turn signal switch and the lights still stay on. One clue however when I pull the 5 amp "Gauges" fuse the lights go out.
Looking at the schematic the switched purple wire feeds power to the turn signal switch. From there it powers either the dark blue or light blue wires which feeds the turn signal dash indicator and front turn signal lights.
So what is back feeding the dash T/S lights? Front turn signal lights themselves are good they only come on when turn signals are applied ground are good. Grounds at Instrument cluster check out
