I'm really pulling my hair out here. I put my car away last fall and everything was fine. I changed so turbo related parts and built new headers over the winter. I finally got it all back together and now its leaving a smoke trail from the pass side bank. Under power there is no smoke but it leaves a pretty good fog at light throttle. I've pulled the turbo off that side and there is no signs of leakage. Plugs looked pretty good but #4 had a little oil on it. Ran a compression check all at 150 but 2 and 4 are 140-145. I resealed all the intake rocker studs and eliminated the pcv valve with no luck. Also there is very little blow-by.
I looks like there is oil in the intake plenum but I can't tell where its coming from. I pulled the intake and on the surface of the head below the port for #s 2 and 4 has a little oil on it. The rest don't seem to have that. I'm hoping it is the intake gaskest leaking but they really didn't look that bad. I guess I'll find out tomorrow.
Anyone have any other ideas? If the intakes not it I'm gunna freak. I'm supposed to go racing this weekend but now its not looking good.
