I've been chasing a few gremlins with a new build and think Im finally getting it figured out-Still having a couple problems though.
I built a 388ci with stock heads, lunati voodoo 60103, 9.7 comp, Performer RPM and a Holley 670 Avenger. I have a pretty bad stumble going from cruising idle transitioning into full throttle. This stumble is there when I ease into throttle or when I mash it. I installed the black colored secondary spring and it seemed to help a little (used to have the purple spring).
Put new plugs in yesterday and drove it for about 1 hour then took it home. Plugs came out very clean but with a ash grey color to the wire and the ceramic itself. I could not hear any detonation, however it was pretty cool (45 degs) yesterday.
Ignition is set at 12 deb initial timing with 36 total, using a summit mechanical advance dist and CD box.
Carb settings are factory, jets 65/68, 31 squirter and 6.5 PV. Vacuum readings at idle are pulling 14-15hg.
Im thinking of starting with jetting up a size or two and possibly changing to a 9.5 PV. I have also read that mechanical advance distributors are'nt the best, so Im going to change out to a MSD billet ready to run vacuum advance.
Would it be best to start jetting up or does it sound like a power valve? Once you hit full throttle it does well, but has a big stumble getting there. It also seems to surge a little when under light cruising throttle (45mph) surge....Any help appreciated !
