These braces fit above the rear frame mount. The square "closed" end meets with or slightly overlaps the gas tank brace. The rounded "open" end fits up against the rear wheel housing. Therefore, these braces run mostly perpendicular to the gas tank brace, but turn forward towards the back of the wheel housing.
I wish I could find my pictures but I will try and explain: As you stated on end is flat and the other appears to be rounded. The flat end should have a hole and a nut that is captured in steel. that nut is for the body mount location which is pre-existing on the frame. Try bolting it up with the flat side to body mount and then the curved end pointing towards the wheel well and quarter panel on the outside side of the frame rail. I hope this helps I will continue searching for my pics.
