I've been waiting quite a while to start this thread. I put the car in the garage to start this project in June.
My build is going to be a LS3 I built my self from scratch, bought a new block,crank, forged connecting rods and pistons, Brian Tooley stage II cam and valve springs. Found a set of brand new take off crate motor heads that I had a Very nice 5 angle vale job and some clean up work of the bowl area.
I'm hoping for 475 hp at the rear wheels.
The motor will be cooled with a Dewit's radiator in their Black Ice epoxy with dual electric fans. I'll also be using Wegner Motorsports black FEAD .
This motor will be backed by a new T56 Magnum. With a Hayes "Muscle Car" clutch, pressure plate and flywheel. And of course a new drive shaft.
The 10 bolt diff will get a posi and 373 gears. I put axles in when I did the Big Brake set up. I know the 10 bolt isn't the best choice, but it's what I have until I find a 66 12 bolt. And I do not want a Ford rear end.
The brake and suspension are all ready done. Bear brakes with SC&C suspension. And Boyd wheels.
But I will be adding Hydra boost and Bear master cylinder.
all of the LS swap components are from Holley/Hooker. The motor mounts, trans cross member, headers and exhaust.
Inside will be getting some new stuff also, Vintage Air, Dakota Digital HDX dash with satellite speedo. Also an complete rewire with American Auto Wire Classic Update harness.
This is the car before I parked it back in June
Chevelle (16)A
The reason I'm just getting to this after parking the car Back in June was a big set back.
The first thing in doing the LS swap was new body bushings. I knew I had some problem bolts but what I got into was a complete trunk floor replacement. This turned out to be a pretty big and time consuming project.
Here a little info on that
http://www.chevelles.com/forums/12-body-shop/983410-trunk-floor-i-need-some-advise.html
Now that I'm done with the trunk floor except for final paint. I'm back on the swap.
So by the end of the Thanksgiving weekend I hope to have this new engine and trans set in place and be able to begin mocking up headers, radiator and FEAD.
Of course I have to do a pretty big modification to the trans tunnel.
IMG_20171121_160239453_HDR
Chevelle (16)A
