I have a '69 SS and am having problems with throwout bearings. This will be the third one in less than 5,000 miles. I replaced the Hays clutch with a Centerforce clutch along with their throwout bearing after the first throwout bearing went bad because I thought the Centerforce was better. When these go bad they disintegrate and without much warning! I'm going to go ahead and replace the stock bellhousing with bulletproof bellhousing so while I have it all apart I thought I'd ask for some advice and see if any of you have had this problem and how you fixed it.
