I have a '68 chevelle, i'm in the process of doing a frame off restoration,my car has pdb on the front, and drum on the rear. All the components are brand new, front to rear. I,m able to get dot 5 fluid to the front with no problem, but am having no luck getting fluid to the back. I've tried gravity bleeding,also with no results. It seems that after bench bleeding the master,and hooking up the lines,the system will not progress any further, meaning I can't even get a flow of fluid when I crack the fitting on the master and have my wife depress the brake pedal. It seems that because all my lines are new, and full of air,I can't initiate a flow of fluid. I also have tried to use a hand held vacume pump on the back cyl. with only marginal success. I will also note that I returned the master, thinking it was defective, and recieved a replacment. As I have noted, all components are brand new, not refurbished. Any ideas would be welcomed.(I'm still able to bench bleed the master,just can't get any further.)
