Fortunately on drivers door and garage door frame and wall. damaged.wall is easy fix car door should not be too bad. This is a 2004R trans in a 66. I was working on carb and dist with car ramming. And drivers door partially open. All. Of a sudden it started going backwards. Door hit garage wall frame and fortunately stopped.
what can I do so this never happens again, besides blocking the wheels and setting the parking brake? Is there some kind of adjustment? 66 steering column modified for T350 and hooked up to the 2004R.
