The area where the fluid is read on the dipstick is broken off and I don't know what the original length it's supposed to be. I bought a replacement at the auto store, but it's too long (it said TH350 on the package). I've looked at my chevelle manuals, but no luck. Thanks! Jessica
71 Malibu
350 V-8
2 barrel carb.
I just went through the same issue. The TH350 tranny calls for either a 34 inch or a 27 inch stick depending on the tube length. I have a TH350 with a 27 inch stick. Measure what you have and that will tell you what you need. The only caveat is if the tube you have was replaced with one other than what the tranny called for.
