This all started last year when two teeth broke off of the fourth gear on my Doug Nash 4+1 5 speed transmission.
Replacement parts are almost non existent,but I managed to find both of the fourth gears used at a decent price.
I pulled the tranny out the other week and took it out to my buddy's transmission shop in my hometown.
He pulled it apart and I did all the clean up and helped take the gears off of the shafts and press the new ones on.
With the shafts assembled,I put it all back together and sealed it up and tightened it up.
The new Long shifter,tweaked by Jody Haag,was mocked up and a back up light switch bracket was made and installed by me.
I put it all back together,got the new shifter on,and went for a test drive.and everything worked just fine.
After almost 20 years of shifting with the old Hurst Vertical Gate II Inline shifter it sure was different using an H pattern model.
I havent quite finished this project as the trans tunnel needs some fabrication,and I also plan on putting new black carpet in to replace the grey thats in there now.Ever since I put the Scat Procar seats in that have black on the sides and grey in the middle I have wanted to put black carpet in.
I'll post some pictures and maybe a video when I get a chance.
Guy
Guy
