Anyone familar with this type of regulator for 66 Chevelle with original Alternator ?? can it be used with my stock Alt.??
The correct number for the Wells unit is VR715. However, if I recall, the Delco Remy electronic regulator was externally adjustable. I would assume that it could be used, however, I'm not absolutely certain. Have to drag my old books out to look at the schematic.
MalibuJerry350
TC Member #1279
Original owner '70 Chevelle.
597,000 miles on car.
Hey, if it's got wheels, DRIVE IT!
My Chevelle: http://hometown.aol.com/erie614/myhomepage/index.html
Thanks guys , yes the Delco Remy transistorized regulator that I have is externally regulated ..... so should be a good item for me to use on with my stock 66 ALT ??
I misread that question. I thought you were asking about just a transistorized or electronic regulator, no the GM one specifically.
I can't think of any reason you couldn't. So stick it in and see what happens. It should work better than the old points regulator.
I'd expect it to just be a late replacement for the points regulators before the internally regulated alternators were built.
Peter
Actually it's a NOS part I came across, it is larger than the std regulator and has an aluminum body with Delco-Remy cast in it also has cooling fins .The external adjustor set screw has a pointer on it and the body has - and + markings . I thought it came on the cars with the transistor ignition option ?? But will install ,looks to good not to use.
