I want to make sure my transmission lines are connected correctly to my 4 core. Does the output side of the trans connect to the upper or lower fitting on the radiator?
Once I verify this, I'm going to install a inline trans cooler with fan in series on the input side to the radiator. I assume I'll need a 3/8 flaring tool to custom make my new lines.
Not sure about your car since you didn't say what it is but a quick bump of the starter with the coil wire off will tell you which cooling line is the outlet if you disconnect them both. Fluid will come out the outlet quickly. Have something to catch it in.
Thanks.....Now going to decide where to mount this thing. I'm leaning toward the wheel well (engine side) with spacers and a fan so it blows off the heat before getting to my radiator.
jwd71_454 not to criticize you or anything but is this your opinion or a fact? I've worked on several different Gm cars and the factory runs the trans output cooler line to the top of the radiator and the return on the bottom.
