Did ok and then I didn't. My combo is pretty mild except a weiand 142 supercharger turning 6psi boost. on 8.8 compression.
I only made three runs but should have opted to stay to make the final run of the day. Last runs we all had a tail wind from out of the blue and temps dropped 10deg. My 2 buddies dropped 1.5 tenths on thier last runs.....only if I had stayed.....
[email protected] 2.002 60ft coolant temp was at 180f during launch.
[email protected] 1.994 60ft coolant temp was at 200f during launch!!!!
BEST! [email protected] 1.822 60ft coolant temp was at 165f during launch.
I finally got a good hook at stalling at a mere 1500rpms! Converter flashed to almost 4k rpms and hooked good. Honestly theres alot more left on the table considering my car is full weighted with power steering,pump gas,steel wheels,small summit cam and not to mention.....Its primered....
future upgrades are
1 Larger cam(23x/24x @.050 atleast) ,electric water pump
2 more boost with the 2.50" pulley v.s. my 2.85" pulley
3 less restrictive air filter housing
4 higher octane fuel
5 minor suspension upgrades I.E; better trailing arms and trick springs
11.8's is goal with mini blower which should be possible.
CONGRATS!!!!! I think 11's are definately in your near future.....
What kind of fuel system are you running??
