Hi people
,have 2 questions.I just got a new G.M crate engine,H.O.350.Do I need a 2200 stall converter,here is my set-up,
H.O 350
compression 9.1:1
cylinder head,vortec,cast iron,23deg valve angle
valve diameter 1.94/1.50
chamber volume 64cc
crank shaft, iron nodular.1 piece rear seal
rods forged power metal,3/8 bolts
pistons cast aluminum
camshaft hydralic flat tapped
lift .435 intake,.460 exhaust
duration 212 intake,222 [email protected] tappet lift
centerline 109 deg ATDC intake, 116 BTDC exhaust
rocker arm ratio 1.5:1(flat tapped)
dynomax 1 3/4 ceramic headers,3in collectors,2 1/2 in dual exhaust,with h-pipe
edelbrock rpm intake,vortec
speed demon 650
HEI distributor,summit
350 turbo trans -shift kit
10 bolt posi-rear,373 gear
15 in rims
Ive allready bought a summit 2200 stall,a friend says I need one,but what do you all think.I would like it to launch good,but really dont know if its too much with this set-up
also ,a shift kit,looks easy,is it really that easy.What do you think.
Thanks again
Rick
[This message has been edited by fatlip (edited 01-21-2002).]
Here's my 02 cents. Call ATI, (best converter!), tell them what you have and they will set you up with the perfect converter for your application. Only cost me $370.00. A little more than some others, but the quality is worth it........bk
No, you don't NEED the converter...I ran a much larger cam on a stock converter.........
BUT....You'll love the way it launches with a higher stall.
If it was me, I would definetely run it!
If you've already got the 2,200 stall convertor I'd use it. You could use a stock convertor, but a 2,200 stall is not much and it would work good especially in a daily driver.
I agree with 69 ElcoBear. Save your money and use what you've got unless your going racing.
That 2200 actually sounds like a good choice for your set up, IMO. It should perform like a stock one during normal driving and give a pretty good launch too.
Bob Von Kaenel
70 SS 402ci TH400
