Ok,
Reference thread from a couple years ago when I picked up a used transmission: Is this 200-4r modified for non-lockup?
I'm finally installing this transmission, hoping it works ok. I'm pretty sure I have my torque converter fully seated, but I measure a 7/8" distance from bellhousing mounting surface to TC pads. According to info I found on the internet, I see:
Seems like I'm about 1/4" too far out. I installed a new flexplate (pioneer sold under Summit brand), and when I fit the trans to the block, the torque converter pads are touching the flexplate pads. I don't want to tighten it up, since it seems I'm missing that 3/16" gap or so...
I've been spinning/pushing on the torque converter, wiggling it, etc, but can't seem to get it to go the final 1/4". I haven't been able to find a published dimension on the 200-4r torque converter so that I can measure this TC to make sure it's a proper length. I expect that I'm just not getting it fully seated or something. But would love to measure to make sure the TC is the proper dimension from pad to end of converter hub.. Wondering, were there any torque converter applications for this transmission that would differ from standard small-block + flexplate ? I think that's supposed to be 1" from mounting pad on flexplate to block, according to something I found on the net.
Thanks in advance!
- GM-TH350, Powerglide=1.125” from bellhousing to the converter pads.
- GM-TH400=1.187” from bellhousing to converter pads.
- GM 700 R4, 4L60E, 200-4R=1.125” from bellhousing to converter pads.
- GM 4L80E=1.030” from bellhousing to converter pads.
Thanks in advance!
