We all know torque and HP cross at a given point. That is accepted but have you ever thought about cam duration. The intake side is a depression that we are filling with air and fuel. Early in timing we are the beginning of this and now where near the lift that we reach maximum cylinder fill, therefore depending on the heads intake track flow characteristics at higher lift the duration numbers should be holding on to fill the cylinder.
Now on the exhaust it is under extreme pressures. As soon as the valve is cracked exhaust wants out. The time need to do this happens very quickly at lower tappets heights. Since this is case at higher tappet heights the duration is going to fall off since the majority of the gas has already escaped.
So a cam that is say a 6 degree split at Adv, .050, and .100, .200, .300" and so forth the duration difference never intersects. Why? Why not?
