My friend is helping me move some stuff around in their 2012 Chevrolet 1500 V8 4X4 with like 400k miles on it. About half that mileage was in-tow behind a larger truck, so its still all original drivetrain.
There is a bad valve tap on the right bank, possible exhaust manifold crack, and Dexcool consumption through the motor that requires constant topping off for proper thermostat functioning. Heavy acceleration, which we try to avoid, causes the exhaust to smoke white and has recently also been accompanied by a Stabilitrack/Safe-Mode alert kicking in.
Does anyone have suggestions based on similar experiences or general knowledge about these trucks? Of the many motor-glue type products available, can anyone refer a block/gasket sealer for the coolant here?
The electronic 4x4 engagement, or disengagement more specifically, has been tricky. It was suggested at the parts store that this could be a $400 electronic actuator mechanism that piggybacks the transfer case. Any general advice here would be helpful, along with comments on the hypothesis that this is causing the Stabilitrack to go haywire.
I am going to repay the favor today by replacing the tailpipe and changing the oil, so please let me know what I should also try to look into further.
Thanks in advance!
Thanks in advance!
