I just fired up my 454 after changing the camshaft, lifters, springs, and intake manifold. I thought the top end sounded a little noisy, so I popped off the valve covers thinking that some adjusting of the valve lash was in order. The rocker adjustments did not seem that loose to me. While turning the engine over remotely with the coil wire unhooked, I noticed that no oil seems to be coming up through the push rods. Why not? Did I overlook something? Engine made 70 PSI oil pressure when I first fired it. Thanks
[This message has been edited by BillB (edited 06-07-99).]
