Finally assembled long block (454 Mk IV)) with help from a friend. Did not have a dial indicator at the time to check end play. Now that cam plug and timing cover are on, I located a dial indicator and I'm showing about .021 of end play. Dial is not completely perpendicular to lobe but I feel the reading is close. Not comfortable leaving with this much play. Do I...
I just can't see leaving this and risk damage to a new distributor gear, possible timing issues or worst case, have lifters shaving edge of lobes from too much walk...
- Locate a longer nylon button and trim to size with current stock timing cover ?? (Currently have the CompCam #205 button .945" length installed)
- Drop $160 on a Cloyes cover and remove the nylon button and adjust using thier roller button setup ?? Read about possible clearance trouble using the Cloyes 9-231 cover with a 8" balancer or short water pump. (rather use that cash towards other parts)
- Tack in a thin piece of metal to inside of cover and trim current nylon button to achieve .007 - .010 end play ??
