Click the thumbnail below and you will see the current status of a TH400 to TKO600 upgrade. I wasn't cool with the stock bend shift lever supplied with the kit, cuz the reach was a little longer than I like with my shoulder's partially torn rotator cuff. So bought different bend lever, clipped it, and welded it back together so that the lever is centered over the transmission nub. I also used the rear mounting position for the shift housing, which required moving the console back about an inch.
Anyway, I can't use the stock slide plates with my new console top plate. I need a boot to cover the gaping hole. I know I won't find one off-the-shelf, has anyone ever had one custom made? I am thinking leather... 4 appropriately proportioned triangles sewn together would do the trick, bit I am not that tricky.
Any leads for me?
Any leads for me?
