Done a search, My question deals with because of my t-ram setup and the total timing I need which is about 36. I'm ready to drop the MSD streetfire in. Should I set the mark at 36 out of the gate? and then go from there so I have 'adjustment/turning room' of the dizzy? or should I set it at 12 or 20 or whatever and go from there?. 11:1 comp.
Thanks for all the help I've got so far.
36 total is a combination of inital, and mechanical. Set the inital at 12-16, and raise the RPM till you get full advance of the machanical, see if you have 36? You do need a setback timming light to do this, or have timming tape on the balancer.
