So I've been trying to tackle a lack of cooling issue with the 396 I just out in my 65. After a lot of trial and error I believe it's coming down to timing. Today I bought a new distributor, an MSD Pro Billet with vacuum advance.
Here's my dilemma. A good friend of mine, who I really do trust and is a good mechanic, has set the initial timing at 12 degrees w/vacuum advance disconnected. We didn't change the springs that came from the factory so this puts the total timing at 32 degrees.
From everything I've read the total timing should be at 36-38 degrees and I believe if this were the case it would help my cooling issue.
The 396 does have a Comp Cams cam, roller rockers, bored 30 over (as far as we know) so the 32 degrees total just doesn't seem right. Timing is definitely something I need to learn more about but until I do I'm hoping you all can help. If you need any add'l info just let me know. Any help will be appreciated.
