i've read some of the threads in the engine forum and most have made sense but i have a question:
i have an edelbrock carb and there are two ports for vacuum advance. the cd that comes with the carb tells me to use the left port (which doesn't suck until you throttle up). the other port sucks all the time. i need to start from scratch and have someone tell me where to set the initial timing, which port to plug my vacuum advance into and where i should be at 3000 range. i had a q-jet before using the maniofold vacuum port (sucked all the time) and never had pinging. once i put this edelbrock on, i've had to keep screwing with it.....HELP!!!
