Well some of you may be aware I lost my flat tappet at startup so I will be going with a roller. I am planning keep the duration around 220 with a lift around .500 for street ability. I have always been a flat tappet guy with one exception my L82 Z28. So here is my dilemma I have factory AC and the brackets lay right on top of the valve covers. I remember Z and I had to run taller valve covers to gain clearance. My roller rockers were Pro Magnum full rollers. Can I stay with my regular Elgin rockers to eliminate the height issue at the cost of some HP. At what lift do I need elongated rocker slots? Are there any quality roller rockers that will fit under a stock valve cover. Thanks
