I'm putting the quick ratio Monte SS steering box in my 71 and to avoid trying to mate it to the original column, I want to put a tilt wheel from an SS in as well. Any problems in my future?
jpete,
there should be no problems now or in the future as this is a bolt in swap. There is no difffernece between a tilt column from a standard as far as bolt in. Just be sure you use a big block intermediate center steering shaft if you have a big block. If its a small block you are ok either way.
"Details Make the Difference"
Musclecar Restoration and Design
Can you explain the diffrence between these to shafts?
JD
JD
Late model Monte's are metric and obviously my Chevelle is standard. I'm not sure EXACTLY what the difference is but when I read about the steering box swap, it says you need some sort of adapter to mate them. I figured I just throw the whole column in and get tilt and move my shifter to the floor at the same time.
jpete,
My mistake, I assumed you meant 70-71 Monte SS not late model. Can't help you there.
JD, the difference in the shafts is at the rag joint end. Big blocks use a splined couplibg that is removeable and uses a 12 point cross bolt to hold it on. The small block units use a welded flange and are not removeable.
jpete -
As you probably know, I am getting ready to do the same swap. I grabbed a tilt column out of a 77 Grand Prix that matches the 'pinch bolt' design of my original 70 column where the intermediate shaft connects. I have read that you can use the coupler (rag joint) from a 78-84 Chevy P/U with these boxes - it has the correct spline for the box and mates with the original intermediate shaft. I grabbed one at the wrecking yard yesterday, so I will be able to tell you soon if it works (Next week?). If it doesn't, I have heard Lee Manufacturing has a couple that works. They also make inserts that adapt your SAE lines to the metric box...but I found another way. If you take the pressure fitting out of the G-Body power steering pump (1" Socket), it will screw into your existing pump. Then get the hoses for the G-Body. Again this is all from what I have read, once I get into it, I will let you know what I find out!!! Hope this helps.
p.s. Thanks for the info. on the quick ratio box and prop. valves.
Brian
1970 Chevelle Malibu
355 ci with
Holley Projection-4
Global West A-Arms
Pics of My 70
Mechanic's Mathematics - Software to do Automotive Calculations
AutoBinder - Software to store information about your car (Body, Interior, Stereo, Engine, Exhaust, Drivetrain, Suspension, Maintenance, Lists) - Coming Soon!!!
