Need to know overall length of the steering
shaft. The measurement would be from the lower splined end where the pot joint attaches to the upper splined end where the steering wheel hub goes. Bought this column at swap meet and discovered shaft was not long enough to attach pot joint. Upon disassembly discovered shaft was actually two piece, upper part with yoke is press fitted into lower part. Somehow this shaft has been compressed, shortening its length. Have figured out how to lengthen but need to know correct measurement. Would the shaft from a non tilt column be the same overall length. Thank for any replies.
