i was putting a tilt col. in my 70 last night, and when i put the ign switch on the column and ck. the adjustment, it was reversed-when i turn the ign to the start position, the rod moves backwards, towards the driver, not the front like it should-i had the ign switch off when i painted it, wondering if there is some type of bellcrank arrangment that somehow the rod went over center, and if i play with it will it go back to the correct way? hope this makes since
wish i had an exploded view of the col, then i would know how it hooks up in there
anyone had this problem b4
