I have a 1967 chevelle, and i'm having problem with getting slack in the fork to throw out bearing, I thing I install the bearing wrong in the fork, I slide the end into the spring, and someone told me that It just between the were the spring rest on the back of the bearing instade of hooking in the sring ,can anyone show a diagram of It, It a four speed muncie thanks In advance
EddieC67ss said:
Did you change bellhousings? If so there are 2 different size piviot balls. The chevelles take the longer one.
Yes I change the bellhousing I went to an 11" clutch, hays clutch pressure plate, and throut bearing,It has a big block in it, so what u are saying Is the spring connect to the rear of the bearing, Thanks again.
