1 - 2 of 2 Posts
I am working on a 67 Chevelle with a sbc(edelbrock carb) and 700r4. Looking for a clean execution for the throttle rod and 700r4 cable. Anyone using a particular brand that works well and looks good. Lokar cables need a different gas pedal to work and it is way too expensive.
I know the Lokar setup is a bit pricy, but it does make for a clean installation. You don't need to go with the stainless cable. I went with the simple black cable.
I changed my Cutlass from a very complicated factory bellcrank setup to the Lokar assembly. Very nice setup and easy to install. Lokar said it wouldn't fit, but it bolted right in.
1 - 2 of 2 Posts
