I got a 1" spacer to put on my carb to give me the PVC hole, and my cable is not long enough. Do you guys know how these cables are measured when they say 24" or 36"? Is that from end to end? Also has anyone tried the Lokar "Universal cables?"
The car is '68 Chevelle.
Thanks.
www.yannis68chevelle.com
The Lokar cable is the way to go. I am using one and there are numerous adjustment points on it to make it the length you need. It sure looks good which does not hurt. Good luck.
Frank
Gold Member # 216
My_Home_Page
Thank you, are you refering to the universal one? Also, do you know for a '68 Chevelle if I would need the 24" or the 36" one? Or how do I measure to find out. These are the 2 lengths that the cable comes with.
Thanks again for your help.
Yanniz I used the 36" and had about 24" too much.Also there are two different cables one has a black housing and the other is silver.I think "HT" is the silver
Yes the housing and cable both get cut to fit
yanniz go here www.jegs.com and look up the online catalog and go under Fuel Systems then click Lokar throttle cables and CSI t c brackets this will give you a perfect pic of the cable and bracket I used
